Time Before: 0.03061 seconds
Time After: 0.04619 seconds
Time Taken: 0.01558 seconds
Time Before: 0.04629 seconds
Time After: 0.04678 seconds
Time Before: 0.04709 seconds
Time After: 0.04724 seconds
Time Before: 0.04820 seconds
Time After: 0.05107 seconds
Time Taken: 0.00287 seconds
Time Before: 0.04732 seconds
Time After: 0.05652 seconds
Time Taken: 0.00920 seconds
Time Before: 0.07287 seconds
Time After: 0.07309 seconds
Time Before: 0.07536 seconds
Time After: 0.07654 seconds
Time Taken: 0.00118 seconds
Time Before: 0.07220 seconds
Time After: 0.07680 seconds
Time Taken: 0.00461 seconds
Time Before: 0.12380 seconds
Time After: 0.12395 seconds
Time Before: 0.51819 seconds
Time After: 0.51951 seconds
Time Taken: 0.00133 seconds
End call of global.php: 0.52217817306519
Time Before: 0.52887 seconds
Time After: 0.52903 seconds
Time Before: 0.53209 seconds
Time After: 0.53365 seconds
Time Taken: 0.00156 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=118594', badlocation = 1
Time Before: 0.55419 seconds
Time After: 0.55444 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
Page generated in 0.55314302444458 seconds with 9 queries, spending 0.0083527565002441 doing MySQL queries and 0.54479026794434 doing PHP things.
