Time Before: 0.00154 seconds
Time After: 0.00210 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00217 seconds
Time After: 0.00307 seconds
Time Taken: 0.00090 seconds
Time Before: 0.00339 seconds
Time After: 0.00435 seconds
Time Taken: 0.00096 seconds
Time Before: 0.00520 seconds
Time After: 0.00760 seconds
Time Taken: 0.00241 seconds
Time Before: 0.00443 seconds
Time After: 0.01102 seconds
Time Taken: 0.00659 seconds
Time Before: 0.01286 seconds
Time After: 0.01305 seconds
Time Before: 0.01611 seconds
Time After: 0.01753 seconds
Time Before: 0.01225 seconds
Time After: 0.01778 seconds
Time Taken: 0.00553 seconds
Time Before: 0.02475 seconds
Time After: 0.02492 seconds
Time Before: 0.02692 seconds
Time After: 0.02814 seconds
Time Before: 0.03110 seconds
Time After: 0.03124 seconds
Time Before: 0.03327 seconds
Time After: 0.03472 seconds
UPDATE session SET lastactivity = 1780641424, location = '/forums/private.php?do=newpm&explain=1&u=118602' WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.05064 seconds
Time After: 0.05097 seconds
