Time Before: 0.00183 seconds
Time After: 0.00236 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00243 seconds
Time After: 0.00301 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00324 seconds
Time After: 0.00339 seconds
Time Before: 0.00404 seconds
Time After: 0.00677 seconds
Time Taken: 0.00273 seconds
Time Before: 0.00344 seconds
Time After: 0.01015 seconds
Time Taken: 0.00671 seconds
Time Before: 0.01212 seconds
Time After: 0.01233 seconds
Time Before: 0.01460 seconds
Time After: 0.01588 seconds
Time Before: 0.01153 seconds
Time After: 0.01606 seconds
Time Taken: 0.00453 seconds
Time Before: 0.02123 seconds
Time After: 0.02144 seconds
Time Before: 0.02363 seconds
Time After: 0.02494 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.026632070541382
Time Before: 0.02782 seconds
Time After: 0.02795 seconds
Time Before: 0.02985 seconds
Time After: 0.03126 seconds
Time Taken: 0.00140 seconds
SET lastactivity = 1785284672, location = '/forums/private.php?do=newpm&explain=1&u=118670'
Time Before: 0.04400 seconds
Time After: 0.04434 seconds
Page generated in 0.043130159378052 seconds with 9 queries, spending 0.0083234310150146 doing MySQL queries and 0.034806728363037 doing PHP things.
