Time Before: 0.00189 seconds
Time After: 0.00255 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00265 seconds
Time After: 0.00313 seconds
Time Before: 0.00342 seconds
Time After: 0.00360 seconds
Time Before: 0.00444 seconds
Time After: 0.00733 seconds
Time Taken: 0.00289 seconds
Time Before: 0.00368 seconds
Time After: 0.01195 seconds
Time Taken: 0.00827 seconds
Time Before: 0.01409 seconds
Time After: 0.01449 seconds
Time Before: 0.01708 seconds
Time After: 0.01949 seconds
Time Taken: 0.00241 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01328 seconds
Time After: 0.01976 seconds
Time Taken: 0.00648 seconds
Memory After: 2,261.820 KB
Time Before: 0.02733 seconds
Time After: 0.02751 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.03110 seconds
Time After: 0.03239 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.03660 seconds
Time After: 0.03679 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.04006 seconds
Time After: 0.04271 seconds
Time Taken: 0.00266 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788973876, location = '/forums/private.php?do=newpm&explain=1&u=118679' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.06182 seconds
Time After: 0.06213 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
