Time Before: 0.02959 seconds
Time After: 0.03961 seconds
Time Taken: 0.01002 seconds
Time Before: 0.03977 seconds
Time After: 0.04124 seconds
Time Before: 0.04149 seconds
Time After: 0.04165 seconds
Time Before: 0.04244 seconds
Time After: 0.04464 seconds
Time Taken: 0.00220 seconds
Time Before: 0.04173 seconds
Time After: 0.04894 seconds
Time Taken: 0.00721 seconds
Time Before: 0.06215 seconds
Time After: 0.06256 seconds
Time Before: 0.06546 seconds
Time After: 0.06796 seconds
Time Taken: 0.00250 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.06148 seconds
Time After: 0.06823 seconds
Time Taken: 0.00675 seconds
Memory After: 2,261.703 KB
Time Before: 0.12170 seconds
Time After: 0.12221 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.14441 seconds
Time After: 0.14570 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.16300 seconds
Time After: 0.16319 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.16659 seconds
Time After: 0.16806 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=118686' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.18986 seconds
Time After: 0.19026 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
