Time Before: 0.03323 seconds
Time After: 0.04605 seconds
Time Taken: 0.01281 seconds
Time Before: 0.04614 seconds
Time After: 0.04658 seconds
Time Before: 0.04684 seconds
Time After: 0.04760 seconds
Time Taken: 0.00076 seconds
Time Before: 0.04845 seconds
Time After: 0.05114 seconds
Time Taken: 0.00269 seconds
Time Before: 0.04768 seconds
Time After: 0.05499 seconds
Time Taken: 0.00730 seconds
Time Before: 0.07013 seconds
Time After: 0.07049 seconds
Time Before: 0.07292 seconds
Time After: 0.07412 seconds
Time Before: 0.06953 seconds
Time After: 0.07433 seconds
Time Taken: 0.00481 seconds
Time Before: 0.10874 seconds
Time After: 0.10890 seconds
Time Before: 0.13843 seconds
Time After: 0.13974 seconds
Time Taken: 0.00131 seconds
Time Before: 0.15376 seconds
Time After: 0.15391 seconds
Time Before: 0.15661 seconds
Time After: 0.15806 seconds
UPDATE session SET lastactivity = 1784768912, location = '/forums/private.php?do=newpm&explain=1&u=118703', badlocation = 1 WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.17708 seconds
Time After: 0.17738 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
