Time Before: 0.01988 seconds
Time After: 0.02577 seconds
Time Taken: 0.00589 seconds
Time Before: 0.02587 seconds
Time After: 0.02640 seconds
Time Taken: 0.00053 seconds
Time Before: 0.02665 seconds
Time After: 0.02679 seconds
Time Before: 0.02762 seconds
Time After: 0.02991 seconds
Time Taken: 0.00229 seconds
Time Before: 0.02687 seconds
Time After: 0.03367 seconds
Time Taken: 0.00680 seconds
Time Before: 0.04317 seconds
Time After: 0.04342 seconds
Time Before: 0.04569 seconds
Time After: 0.04707 seconds
Time Taken: 0.00139 seconds
Time Before: 0.04224 seconds
Time After: 0.04733 seconds
Time Taken: 0.00509 seconds
Time Before: 0.08686 seconds
Time After: 0.08703 seconds
Time Before: 0.44246 seconds
Time After: 0.44383 seconds
Time Taken: 0.00137 seconds
Time Before: 0.45333 seconds
Time After: 0.45345 seconds
Time Before: 0.45561 seconds
Time After: 0.45709 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=118704' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.47463 seconds
Time After: 0.47498 seconds
