Time Before: 0.00134 seconds
Time After: 0.00191 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00198 seconds
Time After: 0.00252 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00279 seconds
Time After: 0.00292 seconds
Time Before: 0.00359 seconds
Time After: 0.00624 seconds
Time Taken: 0.00265 seconds
Time Before: 0.00297 seconds
Time After: 0.00969 seconds
Time Taken: 0.00672 seconds
Time Before: 0.01152 seconds
Time After: 0.01182 seconds
Time Before: 0.01464 seconds
Time After: 0.01604 seconds
Time Taken: 0.00140 seconds
Time Before: 0.01091 seconds
Time After: 0.01622 seconds
Time Taken: 0.00531 seconds
Time Before: 0.02258 seconds
Time After: 0.02281 seconds
Time Before: 0.02499 seconds
Time After: 0.02625 seconds
End call of global.php: 0.027980089187622
Time Before: 0.02916 seconds
Time After: 0.02929 seconds
Time Before: 0.03143 seconds
Time After: 0.03283 seconds
SET lastactivity = 1783040268, location = '/forums/private.php?do=newpm&explain=1&u=118714'
Time Before: 0.04535 seconds
Time After: 0.04570 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.044450998306274 seconds with 9 queries, spending 0.0083916187286377 doing MySQL queries and 0.036059379577637 doing PHP things.
