Time Before: 0.00161 seconds
Time After: 0.00213 seconds
Time Before: 0.00221 seconds
Time After: 0.00266 seconds
Time Before: 0.00283 seconds
Time After: 0.00295 seconds
Time Before: 0.00388 seconds
Time After: 0.00618 seconds
Time Taken: 0.00230 seconds
Time Before: 0.00303 seconds
Time After: 0.01065 seconds
Time Taken: 0.00763 seconds
Time Before: 0.01309 seconds
Time After: 0.01352 seconds
Time Before: 0.01616 seconds
Time After: 0.01742 seconds
Time Before: 0.01231 seconds
Time After: 0.01768 seconds
Time Taken: 0.00537 seconds
Time Before: 0.02337 seconds
Time After: 0.02352 seconds
Time Before: 0.02551 seconds
Time After: 0.02670 seconds
Time Taken: 0.00118 seconds
End call of global.php: 0.028447866439819
Time Before: 0.02964 seconds
Time After: 0.02979 seconds
Time Before: 0.03196 seconds
Time After: 0.03342 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=118723'
Time Before: 0.04609 seconds
Time After: 0.04792 seconds
Time Taken: 0.00184 seconds
Page generated in 0.045202016830444 seconds with 9 queries, spending 0.0093410015106201 doing MySQL queries and 0.035861015319824 doing PHP things.
