Time Before: 0.00184 seconds
Time After: 0.00307 seconds
Time Before: 0.00315 seconds
Time After: 0.00415 seconds
Time Taken: 0.00099 seconds
Time Before: 0.00440 seconds
Time After: 0.00458 seconds
Time Before: 0.00547 seconds
Time After: 0.00787 seconds
Time Taken: 0.00239 seconds
Time Before: 0.00466 seconds
Time After: 0.01337 seconds
Time Taken: 0.00871 seconds
Time Before: 0.01597 seconds
Time After: 0.01640 seconds
Time Before: 0.01884 seconds
Time After: 0.02016 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01524 seconds
Time After: 0.02041 seconds
Time Taken: 0.00517 seconds
Time Before: 0.02723 seconds
Time After: 0.02748 seconds
Time Before: 0.02957 seconds
Time After: 0.03082 seconds
Time Before: 0.03371 seconds
Time After: 0.03385 seconds
Time Before: 0.03592 seconds
Time After: 0.03770 seconds
Time Taken: 0.00177 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=118754', badlocation = 1 WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.05043 seconds
Time After: 0.05077 seconds
