Time Before: 0.00264 seconds
Time After: 0.00336 seconds
Time Taken: 0.00072 seconds
Time Before: 0.00346 seconds
Time After: 0.00414 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00438 seconds
Time After: 0.00448 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00515 seconds
Time After: 0.00817 seconds
Time Taken: 0.00302 seconds
Time Before: 0.00453 seconds
Time After: 0.01155 seconds
Time Taken: 0.00702 seconds
Time Before: 0.01353 seconds
Time After: 0.01424 seconds
Time Before: 0.01661 seconds
Time After: 0.01792 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01269 seconds
Time After: 0.01809 seconds
Time Taken: 0.00540 seconds
Memory After: 2,261.820 KB
Time Before: 0.02374 seconds
Time After: 0.02391 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02687 seconds
Time After: 0.02825 seconds
Time Taken: 0.00138 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.030076026916504
Time Before: 0.03224 seconds
Time After: 0.03240 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03460 seconds
Time After: 0.03616 seconds
Time Taken: 0.00156 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789069159, location = '/forums/private.php?do=newpm&explain=1&u=118800', badlocation = 1
Time Before: 0.04851 seconds
Time After: 0.04886 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.047581911087036 seconds with 9 queries, spending 0.009455680847168 doing MySQL queries and 0.038126230239868 doing PHP things.
