Time Before: 0.02461 seconds
Time After: 0.03032 seconds
Time Taken: 0.00571 seconds
Time Before: 0.03040 seconds
Time After: 0.03086 seconds
Time Before: 0.03106 seconds
Time After: 0.03120 seconds
Time Before: 0.03199 seconds
Time After: 0.03489 seconds
Time Taken: 0.00290 seconds
Time Before: 0.03126 seconds
Time After: 0.03906 seconds
Time Taken: 0.00780 seconds
Time Before: 0.04777 seconds
Time After: 0.04799 seconds
Time Before: 0.05045 seconds
Time After: 0.05165 seconds
Time Before: 0.04709 seconds
Time After: 0.05185 seconds
Time Taken: 0.00476 seconds
Time Before: 0.08796 seconds
Time After: 0.08813 seconds
Time Before: 0.56817 seconds
Time After: 0.57027 seconds
Time Taken: 0.00210 seconds
End call of global.php: 0.57230615615845
Time Before: 0.58367 seconds
Time After: 0.58382 seconds
Time Before: 0.58633 seconds
Time After: 0.58787 seconds
Time Taken: 0.00154 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=118806', badlocation = 1
Time Before: 0.60751 seconds
Time After: 0.60774 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.60633897781372 seconds with 9 queries, spending 0.0091180801391602 doing MySQL queries and 0.59722089767456 doing PHP things.
