Time Before: 0.00289 seconds
Time After: 0.00389 seconds
Time Taken: 0.00100 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00400 seconds
Time After: 0.00463 seconds
Time Taken: 0.00062 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00491 seconds
Time After: 0.00502 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00572 seconds
Time After: 0.00821 seconds
Time Taken: 0.00250 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00508 seconds
Time After: 0.01157 seconds
Time Taken: 0.00649 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01356 seconds
Time After: 0.01378 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01643 seconds
Time After: 0.01764 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.01286 seconds
Time After: 0.01789 seconds
Time Taken: 0.00503 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.02642 seconds
Time After: 0.02661 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.03386 seconds
Time After: 0.03515 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.04658 seconds
Time After: 0.04680 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.04905 seconds
Time After: 0.05056 seconds
Time Taken: 0.00150 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=118817', badlocation = 1 WHERE sessionhash = '493329e92668bdfe23f60c8f4163b3e0'
Time Before: 0.06394 seconds
Time After: 0.06427 seconds
Memory Before: 5,998.641 KB
Memory After: 5,998.859 KB
