Time Before: 0.00185 seconds
Time After: 0.00235 seconds
Time Before: 0.00242 seconds
Time After: 0.00304 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00335 seconds
Time After: 0.00348 seconds
Time Before: 0.00441 seconds
Time After: 0.00745 seconds
Time Taken: 0.00305 seconds
Time Before: 0.00356 seconds
Time After: 0.01233 seconds
Time Taken: 0.00877 seconds
Time Before: 0.01443 seconds
Time After: 0.01490 seconds
Time Before: 0.01652 seconds
Time After: 0.01781 seconds
Time Before: 0.01369 seconds
Time After: 0.01798 seconds
Time Taken: 0.00430 seconds
Time Before: 0.02291 seconds
Time After: 0.02306 seconds
Time Before: 0.02541 seconds
Time After: 0.02666 seconds
Time Before: 0.02972 seconds
Time After: 0.02987 seconds
Time Before: 0.03196 seconds
Time After: 0.03336 seconds
Time Taken: 0.00140 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=118831', badlocation = 1 WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04565 seconds
Time After: 0.04591 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
