Time Before: 0.02981 seconds
Time After: 0.03780 seconds
Time Taken: 0.00798 seconds
Time Before: 0.03791 seconds
Time After: 0.03848 seconds
Time Taken: 0.00056 seconds
Time Before: 0.03876 seconds
Time After: 0.03890 seconds
Time Before: 0.03993 seconds
Time After: 0.04213 seconds
Time Taken: 0.00220 seconds
Time Before: 0.03896 seconds
Time After: 0.04614 seconds
Time Taken: 0.00718 seconds
Time Before: 0.05471 seconds
Time After: 0.05511 seconds
Time Before: 0.05647 seconds
Time After: 0.05786 seconds
Time Taken: 0.00140 seconds
Time Before: 0.05406 seconds
Time After: 0.05805 seconds
Time Taken: 0.00399 seconds
Time Before: 0.10463 seconds
Time After: 0.10477 seconds
Time Before: 0.12532 seconds
Time After: 0.12658 seconds
Time Before: 0.13503 seconds
Time After: 0.13518 seconds
Time Before: 0.13742 seconds
Time After: 0.13885 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=118832', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.15553 seconds
Time After: 0.15586 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
