Time Before: 0.00244 seconds
Time After: 0.00305 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00312 seconds
Time After: 0.00353 seconds
Time Before: 0.00375 seconds
Time After: 0.00389 seconds
Time Before: 0.00471 seconds
Time After: 0.00829 seconds
Time Taken: 0.00359 seconds
Time Before: 0.00394 seconds
Time After: 0.01393 seconds
Time Taken: 0.00998 seconds
Time Before: 0.01687 seconds
Time After: 0.01729 seconds
Time Before: 0.02085 seconds
Time After: 0.02206 seconds
Time Before: 0.01612 seconds
Time After: 0.02231 seconds
Time Taken: 0.00619 seconds
Time Before: 0.02830 seconds
Time After: 0.02843 seconds
Time Before: 0.03030 seconds
Time After: 0.03154 seconds
End call of global.php: 0.033241987228394
Time Before: 0.03448 seconds
Time After: 0.03466 seconds
Time Before: 0.03710 seconds
Time After: 0.03899 seconds
Time Taken: 0.00189 seconds
SET lastactivity = 1788986663, location = '/forums/private.php?do=newpm&explain=1&u=118838'
Time Before: 0.05192 seconds
Time After: 0.05223 seconds
Page generated in 0.051031827926636 seconds with 9 queries, spending 0.0095319747924805 doing MySQL queries and 0.041499853134155 doing PHP things.
