Time Before: 0.00234 seconds
Time After: 0.00356 seconds
Time Before: 0.00363 seconds
Time After: 0.00399 seconds
Time Before: 0.00422 seconds
Time After: 0.00440 seconds
Time Before: 0.00514 seconds
Time After: 0.00772 seconds
Time Taken: 0.00257 seconds
Time Before: 0.00446 seconds
Time After: 0.01116 seconds
Time Taken: 0.00669 seconds
Time Before: 0.01307 seconds
Time After: 0.01340 seconds
Time Before: 0.01610 seconds
Time After: 0.01730 seconds
Time Before: 0.01247 seconds
Time After: 0.01748 seconds
Time Taken: 0.00501 seconds
Time Before: 0.02427 seconds
Time After: 0.02446 seconds
Time Before: 0.02684 seconds
Time After: 0.02829 seconds
End call of global.php: 0.029922008514404
Time Before: 0.03119 seconds
Time After: 0.03137 seconds
Time Before: 0.03334 seconds
Time After: 0.03490 seconds
Time Taken: 0.00155 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=118870', badlocation = 1
Time Before: 0.04757 seconds
Time After: 0.04783 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.046667098999023 seconds with 9 queries, spending 0.0082957744598389 doing MySQL queries and 0.038371324539185 doing PHP things.
