Time Before: 0.00854 seconds
Time After: 0.01139 seconds
Time Taken: 0.00285 seconds
Time Before: 0.01150 seconds
Time After: 0.01194 seconds
Time Before: 0.01219 seconds
Time After: 0.01233 seconds
Time Before: 0.01331 seconds
Time After: 0.01566 seconds
Time Taken: 0.00235 seconds
Time Before: 0.01241 seconds
Time After: 0.01995 seconds
Time Taken: 0.00753 seconds
Time Before: 0.02363 seconds
Time After: 0.02406 seconds
Time Before: 0.02750 seconds
Time After: 0.02868 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02298 seconds
Time After: 0.02889 seconds
Time Taken: 0.00591 seconds
Time Before: 0.04335 seconds
Time After: 0.04349 seconds
Time Before: 0.04974 seconds
Time After: 0.05102 seconds
End call of global.php: 0.052932024002075
Time Before: 0.05705 seconds
Time After: 0.05721 seconds
Time Before: 0.05972 seconds
Time After: 0.06126 seconds
Time Taken: 0.00154 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=118882'
Time Before: 0.07916 seconds
Time After: 0.08032 seconds
Time Taken: 0.00116 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
Page generated in 0.078027009963989 seconds with 9 queries, spending 0.0088143348693848 doing MySQL queries and 0.069212675094604 doing PHP things.
