Time Before: 0.02437 seconds
Time After: 0.03204 seconds
Time Taken: 0.00767 seconds
Time Before: 0.03213 seconds
Time After: 0.03256 seconds
Time Before: 0.03282 seconds
Time After: 0.03298 seconds
Time Before: 0.03381 seconds
Time After: 0.03579 seconds
Time Taken: 0.00198 seconds
Time Before: 0.03305 seconds
Time After: 0.04005 seconds
Time Taken: 0.00699 seconds
Time Before: 0.04730 seconds
Time After: 0.04773 seconds
Time Before: 0.05028 seconds
Time After: 0.05147 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04661 seconds
Time After: 0.05167 seconds
Time Taken: 0.00506 seconds
Memory After: 2,261.703 KB
Time Before: 0.10419 seconds
Time After: 0.10440 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.32456 seconds
Time After: 0.32577 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.32873916625977
Time Before: 0.33581 seconds
Time After: 0.33598 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.33920 seconds
Time After: 0.34062 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=118895', badlocation = 1
Time Before: 0.36147 seconds
Time After: 0.36172 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.35986995697021 seconds with 9 queries, spending 0.0074362754821777 doing MySQL queries and 0.35243368148804 doing PHP things.
