Time Before: 0.00142 seconds
Time After: 0.00190 seconds
Time Before: 0.00197 seconds
Time After: 0.00245 seconds
Time Before: 0.00266 seconds
Time After: 0.00278 seconds
Time Before: 0.00347 seconds
Time After: 0.00598 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00283 seconds
Time After: 0.01024 seconds
Time Taken: 0.00741 seconds
Time Before: 0.01212 seconds
Time After: 0.01293 seconds
Time Taken: 0.00082 seconds
Time Before: 0.01551 seconds
Time After: 0.01669 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01146 seconds
Time After: 0.01688 seconds
Time Taken: 0.00542 seconds
Time Before: 0.02225 seconds
Time After: 0.02239 seconds
Time Before: 0.02461 seconds
Time After: 0.02587 seconds
End call of global.php: 0.028603076934814
Time Before: 0.03017 seconds
Time After: 0.03033 seconds
Time Before: 0.03304 seconds
Time After: 0.03454 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1772789183, location = '/forums/private.php?do=newpm&explain=1&u=118898', badlocation = 1
WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.04841 seconds
Time After: 0.04873 seconds
Page generated in 0.046991109848022 seconds with 9 queries, spending 0.0084748268127441 doing MySQL queries and 0.038516283035278 doing PHP things.
