Time Before: 0.01993 seconds
Time After: 0.02822 seconds
Time Taken: 0.00829 seconds
Time Before: 0.02830 seconds
Time After: 0.02920 seconds
Time Taken: 0.00090 seconds
Time Before: 0.02943 seconds
Time After: 0.02954 seconds
Time Before: 0.03034 seconds
Time After: 0.03289 seconds
Time Taken: 0.00255 seconds
Time Before: 0.02960 seconds
Time After: 0.03789 seconds
Time Before: 0.04418 seconds
Time After: 0.04464 seconds
Time Before: 0.04718 seconds
Time After: 0.04839 seconds
Time Before: 0.04344 seconds
Time After: 0.04857 seconds
Time Taken: 0.00514 seconds
Time Before: 0.08079 seconds
Time After: 0.08093 seconds
Time Before: 0.09484 seconds
Time After: 0.09609 seconds
End call of global.php: 0.097991943359375
Time Before: 0.10448 seconds
Time After: 0.10462 seconds
Time Before: 0.10686 seconds
Time After: 0.10832 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=118953', badlocation = 1
Time Before: 0.12507 seconds
Time After: 0.12531 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.12410187721252 seconds with 9 queries, spending 0.0084681510925293 doing MySQL queries and 0.11563372612 doing PHP things.
