Time Before: 0.02712 seconds
Time After: 0.03434 seconds
Time Taken: 0.00723 seconds
Time Before: 0.03444 seconds
Time After: 0.03494 seconds
Time Before: 0.03523 seconds
Time After: 0.03539 seconds
Time Before: 0.03617 seconds
Time After: 0.04030 seconds
Time Taken: 0.00413 seconds
Time Before: 0.03544 seconds
Time After: 0.04489 seconds
Time Taken: 0.00945 seconds
Time Before: 0.05705 seconds
Time After: 0.05743 seconds
Time Before: 0.06018 seconds
Time After: 0.06140 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.05627 seconds
Time After: 0.06163 seconds
Time Taken: 0.00536 seconds
Memory After: 2,261.719 KB
Memory Used: 132.781 KB
Time Before: 0.09869 seconds
Time After: 0.09884 seconds
Memory Before: 2,815.305 KB
Memory After: 2,815.820 KB
Time Before: 0.11851 seconds
Time After: 0.11977 seconds
Memory Before: 2,903.508 KB
Memory After: 2,904.102 KB
Time Before: 0.13273 seconds
Time After: 0.13290 seconds
Memory Before: 3,540.266 KB
Memory After: 3,540.695 KB
Time Before: 0.13546 seconds
Time After: 0.13923 seconds
Time Taken: 0.00377 seconds
Memory Before: 3,821.797 KB
Memory After: 3,823.484 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=118994', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.15905 seconds
Time After: 0.15933 seconds
Memory Before: 4,287.492 KB
Memory After: 4,287.719 KB
