Time Before: 0.03067 seconds
Time After: 0.04054 seconds
Time Taken: 0.00987 seconds
Time Before: 0.04063 seconds
Time After: 0.04273 seconds
Time Taken: 0.00209 seconds
Time Before: 0.04316 seconds
Time After: 0.04331 seconds
Time Before: 0.04418 seconds
Time After: 0.04779 seconds
Time Taken: 0.00360 seconds
Time Before: 0.04340 seconds
Time After: 0.05318 seconds
Time Taken: 0.00978 seconds
Time Before: 0.06423 seconds
Time After: 0.06464 seconds
Time Before: 0.06787 seconds
Time After: 0.07116 seconds
Time Taken: 0.00329 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.06356 seconds
Time After: 0.07138 seconds
Time Taken: 0.00782 seconds
Memory After: 2,261.820 KB
Time Before: 0.11375 seconds
Time After: 0.11395 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.31947 seconds
Time After: 0.32132 seconds
Time Taken: 0.00185 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.32344603538513
Time Before: 0.33222 seconds
Time After: 0.33312 seconds
Time Taken: 0.00089 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.33564 seconds
Time After: 0.33750 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789109259, location = '/forums/private.php?do=newpm&explain=1&u=118999', badlocation = 1
Time Before: 0.35954 seconds
Time After: 0.35980 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.35814809799194 seconds with 9 queries, spending 0.014593362808228 doing MySQL queries and 0.34355473518372 doing PHP things.
