Time Before: 0.00142 seconds
Time After: 0.00192 seconds
Time Before: 0.00199 seconds
Time After: 0.00251 seconds
Time Before: 0.00277 seconds
Time After: 0.00309 seconds
Time Before: 0.00484 seconds
Time After: 0.00693 seconds
Time Taken: 0.00209 seconds
Time Before: 0.00317 seconds
Time After: 0.01039 seconds
Time Taken: 0.00722 seconds
Time Before: 0.01234 seconds
Time After: 0.01273 seconds
Time Before: 0.01417 seconds
Time After: 0.01531 seconds
Time Taken: 0.00114 seconds
Time Before: 0.01177 seconds
Time After: 0.01549 seconds
Time Taken: 0.00372 seconds
Time Before: 0.02060 seconds
Time After: 0.02082 seconds
Time Before: 0.02322 seconds
Time After: 0.02472 seconds
Time Taken: 0.00150 seconds
End call of global.php: 0.026406049728394
Time Before: 0.02767 seconds
Time After: 0.02781 seconds
Time Before: 0.02986 seconds
Time After: 0.03131 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=119022'
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04652 seconds
Time After: 0.04690 seconds
Page generated in 0.045616149902344 seconds with 9 queries, spending 0.008131742477417 doing MySQL queries and 0.037484407424927 doing PHP things.
