Time Before: 0.00148 seconds
Time After: 0.00203 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00210 seconds
Time After: 0.00263 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00283 seconds
Time After: 0.00295 seconds
Time Before: 0.00361 seconds
Time After: 0.00585 seconds
Time Taken: 0.00224 seconds
Time Before: 0.00300 seconds
Time After: 0.00931 seconds
Time Taken: 0.00630 seconds
Time Before: 0.01111 seconds
Time After: 0.01155 seconds
Time Before: 0.01392 seconds
Time After: 0.01518 seconds
Time Before: 0.01046 seconds
Time After: 0.01536 seconds
Time Taken: 0.00490 seconds
Time Before: 0.02020 seconds
Time After: 0.02045 seconds
Time Before: 0.02226 seconds
Time After: 0.02350 seconds
Time Before: 0.02663 seconds
Time After: 0.02676 seconds
Time Before: 0.02881 seconds
Time After: 0.03033 seconds
Time Taken: 0.00152 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=119035', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04257 seconds
Time After: 0.04300 seconds
