Time Before: 0.00855 seconds
Time After: 0.01212 seconds
Time Taken: 0.00357 seconds
Time Before: 0.01222 seconds
Time After: 0.01268 seconds
Time Before: 0.01289 seconds
Time After: 0.01313 seconds
Time Before: 0.01402 seconds
Time After: 0.01652 seconds
Time Taken: 0.00250 seconds
Time Before: 0.01320 seconds
Time After: 0.02070 seconds
Time Taken: 0.00750 seconds
Time Before: 0.02719 seconds
Time After: 0.02756 seconds
Time Before: 0.02949 seconds
Time After: 0.03072 seconds
Time Before: 0.02643 seconds
Time After: 0.03099 seconds
Time Taken: 0.00456 seconds
Time Before: 0.04359 seconds
Time After: 0.04376 seconds
Time Before: 0.05240 seconds
Time After: 0.05364 seconds
Time Before: 0.05900 seconds
Time After: 0.05916 seconds
Time Before: 0.06222 seconds
Time After: 0.06374 seconds
Time Taken: 0.00152 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=119036', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.08416 seconds
Time After: 0.08464 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
