Time Before: 0.00197 seconds
Time After: 0.00265 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00275 seconds
Time After: 0.00342 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00369 seconds
Time After: 0.00390 seconds
Time Before: 0.00454 seconds
Time After: 0.00738 seconds
Time Taken: 0.00284 seconds
Time Before: 0.00395 seconds
Time After: 0.01079 seconds
Time Taken: 0.00684 seconds
Time Before: 0.01283 seconds
Time After: 0.01324 seconds
Time Before: 0.01575 seconds
Time After: 0.01703 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01220 seconds
Time After: 0.01722 seconds
Time Taken: 0.00502 seconds
Memory After: 2,261.703 KB
Time Before: 0.02238 seconds
Time After: 0.02258 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02471 seconds
Time After: 0.02601 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.027692079544067
Time Before: 0.02918 seconds
Time After: 0.02937 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03207 seconds
Time After: 0.03354 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=119040', badlocation = 1
Time Before: 0.04602 seconds
Time After: 0.04638 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.04508900642395 seconds with 9 queries, spending 0.0089170932769775 doing MySQL queries and 0.036171913146973 doing PHP things.
