Time Before: 0.00242 seconds
Time After: 0.00307 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00318 seconds
Time After: 0.00365 seconds
Time Before: 0.00391 seconds
Time After: 0.00406 seconds
Time Before: 0.00509 seconds
Time After: 0.00832 seconds
Time Taken: 0.00323 seconds
Time Before: 0.00414 seconds
Time After: 0.01333 seconds
Time Taken: 0.00919 seconds
Time Before: 0.01559 seconds
Time After: 0.01589 seconds
Time Before: 0.01848 seconds
Time After: 0.01979 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01486 seconds
Time After: 0.02006 seconds
Time Taken: 0.00519 seconds
Time Before: 0.02601 seconds
Time After: 0.02616 seconds
Time Before: 0.02842 seconds
Time After: 0.02964 seconds
End call of global.php: 0.031335830688477
Time Before: 0.03258 seconds
Time After: 0.03271 seconds
Time Before: 0.03465 seconds
Time After: 0.03610 seconds
SET lastactivity = 1776615551, location = '/forums/private.php?do=newpm&explain=1&u=119046', badlocation = 1
Time Before: 0.04935 seconds
Time After: 0.04969 seconds
Page generated in 0.048265933990479 seconds with 9 queries, spending 0.0087435245513916 doing MySQL queries and 0.039522409439087 doing PHP things.
