Time Before: 0.00140 seconds
Time After: 0.00191 seconds
Time Before: 0.00199 seconds
Time After: 0.00265 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00290 seconds
Time After: 0.00304 seconds
Time Before: 0.00377 seconds
Time After: 0.00661 seconds
Time Taken: 0.00284 seconds
Time Before: 0.00309 seconds
Time After: 0.01060 seconds
Time Taken: 0.00750 seconds
Time Before: 0.01242 seconds
Time After: 0.01286 seconds
Time Before: 0.01519 seconds
Time After: 0.01644 seconds
Time Before: 0.01185 seconds
Time After: 0.01663 seconds
Time Taken: 0.00477 seconds
Time Before: 0.02184 seconds
Time After: 0.02201 seconds
Time Before: 0.02391 seconds
Time After: 0.02517 seconds
Time Before: 0.02805 seconds
Time After: 0.02828 seconds
Time Before: 0.03037 seconds
Time After: 0.03177 seconds
Time Taken: 0.00140 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=119051', badlocation = 1 WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.04418 seconds
Time After: 0.04460 seconds
