Time Before: 0.02710 seconds
Time After: 0.03559 seconds
Time Taken: 0.00849 seconds
Time Before: 0.03570 seconds
Time After: 0.03634 seconds
Time Taken: 0.00064 seconds
Time Before: 0.03670 seconds
Time After: 0.03716 seconds
Time Before: 0.03818 seconds
Time After: 0.04059 seconds
Time Taken: 0.00241 seconds
Time Before: 0.03725 seconds
Time After: 0.04473 seconds
Time Taken: 0.00749 seconds
Time Before: 0.05233 seconds
Time After: 0.05259 seconds
Time Before: 0.05487 seconds
Time After: 0.05611 seconds
Time Before: 0.05157 seconds
Time After: 0.05635 seconds
Time Taken: 0.00478 seconds
Time Before: 0.08502 seconds
Time After: 0.08519 seconds
Time Before: 0.11053 seconds
Time After: 0.11181 seconds
End call of global.php: 0.11434507369995
Time Before: 0.12344 seconds
Time After: 0.12363 seconds
Time Before: 0.12618 seconds
Time After: 0.12769 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1789109804, location = '/forums/private.php?do=newpm&explain=1&u=119067'
Time Before: 0.14902 seconds
Time After: 0.14928 seconds
Page generated in 0.14793300628662 seconds with 9 queries, spending 0.0084097385406494 doing MySQL queries and 0.13952326774597 doing PHP things.
