Time Before: 0.00149 seconds
Time After: 0.00194 seconds
Time Before: 0.00201 seconds
Time After: 0.00261 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00287 seconds
Time After: 0.00300 seconds
Time Before: 0.00372 seconds
Time After: 0.00642 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00305 seconds
Time After: 0.00984 seconds
Time Taken: 0.00679 seconds
Time Before: 0.01167 seconds
Time After: 0.01212 seconds
Time Before: 0.01378 seconds
Time After: 0.01514 seconds
Time Taken: 0.00137 seconds
Time Before: 0.01103 seconds
Time After: 0.01548 seconds
Time Taken: 0.00445 seconds
Time Before: 0.02133 seconds
Time After: 0.02152 seconds
Time Before: 0.02349 seconds
Time After: 0.02476 seconds
End call of global.php: 0.026484966278076
Time Before: 0.02806 seconds
Time After: 0.02825 seconds
Time Before: 0.03158 seconds
Time After: 0.03318 seconds
Time Taken: 0.00160 seconds
SET lastactivity = 1785298313, location = '/forums/private.php?do=newpm&explain=1&u=119103', badlocation = 1
Time Before: 0.04591 seconds
Time After: 0.04630 seconds
Page generated in 0.0450119972229 seconds with 9 queries, spending 0.00888991355896 doing MySQL queries and 0.03612208366394 doing PHP things.
