Time Before: 0.00148 seconds
Time After: 0.00200 seconds
Time Before: 0.00208 seconds
Time After: 0.00282 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00317 seconds
Time After: 0.00335 seconds
Time Before: 0.00427 seconds
Time After: 0.00715 seconds
Time Taken: 0.00288 seconds
Time Before: 0.00344 seconds
Time After: 0.01170 seconds
Time Taken: 0.00827 seconds
Time Before: 0.01399 seconds
Time After: 0.01436 seconds
Time Before: 0.01672 seconds
Time After: 0.01796 seconds
Time Before: 0.01315 seconds
Time After: 0.01813 seconds
Time Taken: 0.00499 seconds
Time Before: 0.02332 seconds
Time After: 0.02347 seconds
Time Before: 0.02534 seconds
Time After: 0.02657 seconds
Time Before: 0.02932 seconds
Time After: 0.02950 seconds
Time Before: 0.03152 seconds
Time After: 0.03395 seconds
Time Taken: 0.00244 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=119117', badlocation = 1 WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.04646 seconds
Time After: 0.04682 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
