Time Before: 0.01312 seconds
Time After: 0.01851 seconds
Time Taken: 0.00539 seconds
Time Before: 0.01862 seconds
Time After: 0.01923 seconds
Time Taken: 0.00060 seconds
Time Before: 0.01944 seconds
Time After: 0.01955 seconds
Time Taken: 0.00010 seconds
Time Before: 0.02015 seconds
Time After: 0.02281 seconds
Time Taken: 0.00266 seconds
Time Before: 0.01960 seconds
Time After: 0.02697 seconds
Time Taken: 0.00737 seconds
Time Before: 0.03249 seconds
Time After: 0.03271 seconds
Time Before: 0.03492 seconds
Time After: 0.03624 seconds
Time Taken: 0.00133 seconds
Time Before: 0.03179 seconds
Time After: 0.03646 seconds
Time Taken: 0.00467 seconds
Time Before: 0.06397 seconds
Time After: 0.06409 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:5:\"8.00,\";s:9:\"lastcheck\";i:1783191461;}', 1)Time Before: 0.07827 seconds
Time After: 0.07861 seconds
Memory Before: 2,817.297 KB
Memory After: 2,817.547 KB
Memory Used: 0.250 KB
Time Before: 0.36472 seconds
Time After: 0.36617 seconds
Memory Before: 2,904.625 KB
Memory After: 2,905.219 KB
Time Before: 0.37413 seconds
Time After: 0.37431 seconds
Memory Before: 3,541.398 KB
Memory After: 3,541.828 KB
Time Before: 0.37705 seconds
Time After: 0.37857 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,823.141 KB
Memory After: 3,824.828 KB
UPDATE session SET lastactivity = 1783191461, location = '/forums/private.php?do=newpm&explain=1&u=119131', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.39595 seconds
Time After: 0.39625 seconds
Memory Before: 4,297.125 KB
Memory After: 4,297.336 KB
