Time Before: 0.00155 seconds
Time After: 0.00206 seconds
Time Before: 0.00213 seconds
Time After: 0.00274 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00299 seconds
Time After: 0.00310 seconds
Time Before: 0.00381 seconds
Time After: 0.00626 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00315 seconds
Time After: 0.00964 seconds
Time Taken: 0.00649 seconds
Time Before: 0.01185 seconds
Time After: 0.01231 seconds
Time Before: 0.01470 seconds
Time After: 0.01600 seconds
Time Before: 0.01114 seconds
Time After: 0.01617 seconds
Time Taken: 0.00503 seconds
Time Before: 0.02099 seconds
Time After: 0.02114 seconds
Time Before: 0.02309 seconds
Time After: 0.02439 seconds
Time Before: 0.02713 seconds
Time After: 0.02727 seconds
Time Before: 0.02916 seconds
Time After: 0.03068 seconds
Time Taken: 0.00152 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=119140', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04295 seconds
Time After: 0.04322 seconds
