Time Before: 0.04692 seconds
Time After: 0.05227 seconds
Time Taken: 0.00535 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.05237 seconds
Time After: 0.05282 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.05314 seconds
Time After: 0.05332 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.05411 seconds
Time After: 0.05642 seconds
Time Taken: 0.00231 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.05338 seconds
Time After: 0.06106 seconds
Time Taken: 0.00767 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.07024 seconds
Time After: 0.07070 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.07313 seconds
Time After: 0.07435 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.06949 seconds
Time After: 0.07463 seconds
Time Taken: 0.00514 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.14557 seconds
Time After: 0.14574 seconds
Memory Before: 3,655.742 KB
Memory After: 3,656.258 KB
Time Before: 0.24844 seconds
Time After: 0.24968 seconds
Memory Before: 4,133.320 KB
Memory After: 4,133.914 KB
Time Before: 0.30771 seconds
Time After: 0.30795 seconds
Memory Before: 5,197.516 KB
Memory After: 5,325.859 KB
Time Before: 0.31919 seconds
Time After: 0.32071 seconds
Time Taken: 0.00152 seconds
Memory Before: 5,481.211 KB
Memory After: 5,610.813 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=119203', badlocation = 1 WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.35325 seconds
Time After: 0.35362 seconds
Memory Before: 5,998.508 KB
Memory After: 5,998.727 KB
