Time Before: 0.00176 seconds
Time After: 0.00254 seconds
Time Taken: 0.00078 seconds
Time Before: 0.00261 seconds
Time After: 0.00318 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00344 seconds
Time After: 0.00360 seconds
Time Before: 0.00431 seconds
Time After: 0.00694 seconds
Time Taken: 0.00263 seconds
Time Before: 0.00365 seconds
Time After: 0.01037 seconds
Time Taken: 0.00671 seconds
Time Before: 0.01212 seconds
Time After: 0.01249 seconds
Time Before: 0.01392 seconds
Time After: 0.01622 seconds
Time Taken: 0.00229 seconds
Time Before: 0.01156 seconds
Time After: 0.01640 seconds
Time Taken: 0.00483 seconds
Time Before: 0.02181 seconds
Time After: 0.02196 seconds
Time Before: 0.02401 seconds
Time After: 0.02533 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.027070999145508
Time Before: 0.02841 seconds
Time After: 0.02857 seconds
Time Before: 0.03054 seconds
Time After: 0.03200 seconds
SET lastactivity = 1785297806, location = '/forums/private.php?do=newpm&explain=1&u=119225'
Time Before: 0.04441 seconds
Time After: 0.04475 seconds
Page generated in 0.043508052825928 seconds with 9 queries, spending 0.0094549655914307 doing MySQL queries and 0.034053087234497 doing PHP things.
