Time Before: 0.00189 seconds
Time After: 0.00251 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00262 seconds
Time After: 0.00324 seconds
Time Before: 0.00346 seconds
Time After: 0.00357 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00426 seconds
Time After: 0.00686 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00362 seconds
Time After: 0.01021 seconds
Time Taken: 0.00659 seconds
Time Before: 0.01214 seconds
Time After: 0.01257 seconds
Time Before: 0.01516 seconds
Time After: 0.01645 seconds
Time Before: 0.01134 seconds
Time After: 0.01670 seconds
Time Taken: 0.00536 seconds
Time Before: 0.02232 seconds
Time After: 0.02250 seconds
Time Before: 0.02439 seconds
Time After: 0.02564 seconds
Time Before: 0.02869 seconds
Time After: 0.02888 seconds
Time Before: 0.03093 seconds
Time After: 0.03239 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=119257' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04500 seconds
Time After: 0.04526 seconds
