Time Before: 0.02018 seconds
Time After: 0.02488 seconds
Time Taken: 0.00470 seconds
Time Before: 0.02498 seconds
Time After: 0.02542 seconds
Time Before: 0.02565 seconds
Time After: 0.02580 seconds
Time Before: 0.02655 seconds
Time After: 0.02862 seconds
Time Taken: 0.00207 seconds
Time Before: 0.02585 seconds
Time After: 0.03274 seconds
Time Taken: 0.00689 seconds
Time Before: 0.03837 seconds
Time After: 0.03858 seconds
Time Before: 0.04128 seconds
Time After: 0.04246 seconds
Time Before: 0.03779 seconds
Time After: 0.04273 seconds
Time Taken: 0.00494 seconds
Time Before: 0.07456 seconds
Time After: 0.07471 seconds
Time Before: 0.36728 seconds
Time After: 0.36861 seconds
Time Taken: 0.00133 seconds
End call of global.php: 0.37122106552124
Time Before: 0.37722 seconds
Time After: 0.37738 seconds
Time Before: 0.37969 seconds
Time After: 0.38113 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=119271'
Time Before: 0.39812 seconds
Time After: 0.39840 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
Page generated in 0.39708995819092 seconds with 9 queries, spending 0.0074043273925781 doing MySQL queries and 0.38968563079834 doing PHP things.
