Time Before: 0.00187 seconds
Time After: 0.00240 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00248 seconds
Time After: 0.00320 seconds
Time Taken: 0.00072 seconds
Time Before: 0.00354 seconds
Time After: 0.00369 seconds
Time Before: 0.00437 seconds
Time After: 0.00704 seconds
Time Taken: 0.00267 seconds
Time Before: 0.00374 seconds
Time After: 0.01043 seconds
Time Taken: 0.00668 seconds
Time Before: 0.01230 seconds
Time After: 0.01272 seconds
Time Before: 0.01524 seconds
Time After: 0.01650 seconds
Time Before: 0.01170 seconds
Time After: 0.01668 seconds
Time Taken: 0.00499 seconds
Time Before: 0.02161 seconds
Time After: 0.02177 seconds
Time Before: 0.02376 seconds
Time After: 0.02502 seconds
End call of global.php: 0.026626825332642
Time Before: 0.02794 seconds
Time After: 0.02809 seconds
Time Before: 0.03010 seconds
Time After: 0.03154 seconds
SET lastactivity = 1776647621, location = '/forums/private.php?do=newpm&explain=1&u=119305'
Time Before: 0.04420 seconds
Time After: 0.04452 seconds
Page generated in 0.043269872665405 seconds with 9 queries, spending 0.0085692405700684 doing MySQL queries and 0.034700632095337 doing PHP things.
