Time Before: 0.00157 seconds
Time After: 0.00218 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00229 seconds
Time After: 0.00278 seconds
Time Before: 0.00304 seconds
Time After: 0.00317 seconds
Time Before: 0.00404 seconds
Time After: 0.00629 seconds
Time Taken: 0.00225 seconds
Time Before: 0.00324 seconds
Time After: 0.01007 seconds
Time Taken: 0.00683 seconds
Time Before: 0.01195 seconds
Time After: 0.01232 seconds
Time Before: 0.01372 seconds
Time After: 0.01495 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01137 seconds
Time After: 0.01516 seconds
Time Taken: 0.00379 seconds
Memory After: 2,261.703 KB
Time Before: 0.02103 seconds
Time After: 0.02121 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02304 seconds
Time After: 0.02426 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.025890111923218
Time Before: 0.02706 seconds
Time After: 0.02722 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.02917 seconds
Time After: 0.03060 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=119307', badlocation = 1
Time Before: 0.04450 seconds
Time After: 0.14554 seconds
Time Taken: 0.10104 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.043585062026978 seconds with 9 queries, spending 0.10850858688354 doing MySQL queries and -0.064923524856567 doing PHP things.
