Time Before: 0.00533 seconds
Time After: 0.00657 seconds
Time Before: 0.00666 seconds
Time After: 0.00714 seconds
Time Before: 0.00738 seconds
Time After: 0.00753 seconds
Time Before: 0.00831 seconds
Time After: 0.01090 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00760 seconds
Time After: 0.01455 seconds
Time Taken: 0.00695 seconds
Time Before: 0.01760 seconds
Time After: 0.01782 seconds
Time Before: 0.02046 seconds
Time After: 0.02182 seconds
Time Taken: 0.00136 seconds
Time Before: 0.01691 seconds
Time After: 0.02203 seconds
Time Taken: 0.00513 seconds
Time Before: 0.02924 seconds
Time After: 0.02940 seconds
Time Before: 0.03264 seconds
Time After: 0.03409 seconds
End call of global.php: 0.036535024642944
Time Before: 0.03806 seconds
Time After: 0.03822 seconds
Time Before: 0.04039 seconds
Time After: 0.04190 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=11932', badlocation = 1
Time Before: 0.05539 seconds
Time After: 0.05565 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.054404973983765 seconds with 9 queries, spending 0.0083584785461426 doing MySQL queries and 0.046046495437622 doing PHP things.
