Time Before: 0.00924 seconds
Time After: 0.01211 seconds
Time Taken: 0.00287 seconds
Time Before: 0.01221 seconds
Time After: 0.01263 seconds
Time Before: 0.01285 seconds
Time After: 0.01299 seconds
Time Before: 0.01380 seconds
Time After: 0.01605 seconds
Time Taken: 0.00225 seconds
Time Before: 0.01307 seconds
Time After: 0.02032 seconds
Time Taken: 0.00726 seconds
Time Before: 0.02473 seconds
Time After: 0.02514 seconds
Time Before: 0.02756 seconds
Time After: 0.02876 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02412 seconds
Time After: 0.02895 seconds
Time Taken: 0.00483 seconds
Memory After: 2,261.820 KB
Time Before: 0.04400 seconds
Time After: 0.04422 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.05389 seconds
Time After: 0.05513 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.06178 seconds
Time After: 0.06193 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.06431 seconds
Time After: 0.06574 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789068090, location = '/forums/private.php?do=newpm&explain=1&u=119353' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.08175 seconds
Time After: 0.08201 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
