Time Before: 0.01674 seconds
Time After: 0.02384 seconds
Time Taken: 0.00710 seconds
Time Before: 0.02394 seconds
Time After: 0.02437 seconds
Time Before: 0.02475 seconds
Time After: 0.02494 seconds
Time Before: 0.02581 seconds
Time After: 0.02800 seconds
Time Taken: 0.00219 seconds
Time Before: 0.02501 seconds
Time After: 0.03162 seconds
Time Taken: 0.00661 seconds
Time Before: 0.03944 seconds
Time After: 0.03967 seconds
Time Before: 0.04259 seconds
Time After: 0.04380 seconds
Time Before: 0.03863 seconds
Time After: 0.04405 seconds
Time Taken: 0.00541 seconds
Time Before: 0.06714 seconds
Time After: 0.06731 seconds
Time Before: 0.51112 seconds
Time After: 0.51331 seconds
End call of global.php: 0.51621794700623
Time Before: 0.52081 seconds
Time After: 0.52100 seconds
Time Before: 0.52362 seconds
Time After: 0.52526 seconds
Time Taken: 0.00164 seconds
SET lastactivity = 1783010108, location = '/forums/private.php?do=newpm&explain=1&u=119416', badlocation = 1
Time Before: 0.54242 seconds
Time After: 0.54651 seconds
Time Taken: 0.00409 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
Page generated in 0.54138207435608 seconds with 9 queries, spending 0.012523889541626 doing MySQL queries and 0.52885818481445 doing PHP things.
