Time Before: 0.00134 seconds
Time After: 0.00222 seconds
Time Taken: 0.00087 seconds
Time Before: 0.00233 seconds
Time After: 0.00278 seconds
Time Before: 0.00300 seconds
Time After: 0.00314 seconds
Time Before: 0.00402 seconds
Time After: 0.00866 seconds
Time Taken: 0.00464 seconds
Time Before: 0.00319 seconds
Time After: 0.01323 seconds
Time Taken: 0.01004 seconds
Time Before: 0.01499 seconds
Time After: 0.01521 seconds
Time Before: 0.01794 seconds
Time After: 0.01917 seconds
Time Before: 0.01443 seconds
Time After: 0.01943 seconds
Time Taken: 0.00500 seconds
Time Before: 0.02694 seconds
Time After: 0.02728 seconds
Time Before: 0.03020 seconds
Time After: 0.03143 seconds
End call of global.php: 0.033154010772705
Time Before: 0.03460 seconds
Time After: 0.03474 seconds
Time Before: 0.03677 seconds
Time After: 0.03818 seconds
SET lastactivity = 1788946632, location = '/forums/private.php?do=newpm&explain=1&u=119469', badlocation = 1
Time Before: 0.05048 seconds
Time After: 0.05069 seconds
Page generated in 0.049597024917603 seconds with 9 queries, spending 0.010011196136475 doing MySQL queries and 0.039585828781128 doing PHP things.
