Time Before: 0.00175 seconds
Time After: 0.00226 seconds
Time Before: 0.00233 seconds
Time After: 0.00311 seconds
Time Taken: 0.00078 seconds
Time Before: 0.00346 seconds
Time After: 0.00360 seconds
Time Before: 0.00429 seconds
Time After: 0.00725 seconds
Time Taken: 0.00296 seconds
Time Before: 0.00366 seconds
Time After: 0.01063 seconds
Time Taken: 0.00697 seconds
Time Before: 0.01348 seconds
Time After: 0.01378 seconds
Time Before: 0.01660 seconds
Time After: 0.01785 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01277 seconds
Time After: 0.01804 seconds
Time Taken: 0.00527 seconds
Memory After: 2,261.820 KB
Time Before: 0.02311 seconds
Time After: 0.02333 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02527 seconds
Time After: 0.02654 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.028158903121948
Time Before: 0.02952 seconds
Time After: 0.02967 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03159 seconds
Time After: 0.03311 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788975277, location = '/forums/private.php?do=newpm&explain=1&u=119553', badlocation = 1
Time Before: 0.04605 seconds
Time After: 0.04637 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.045130014419556 seconds with 9 queries, spending 0.0089209079742432 doing MySQL queries and 0.036209106445312 doing PHP things.
