Time Before: 0.01292 seconds
Time After: 0.01820 seconds
Time Taken: 0.00529 seconds
Time Before: 0.01827 seconds
Time After: 0.01879 seconds
Time Before: 0.01903 seconds
Time After: 0.01915 seconds
Time Before: 0.01989 seconds
Time After: 0.02262 seconds
Time Taken: 0.00272 seconds
Time Before: 0.01924 seconds
Time After: 0.02737 seconds
Time Taken: 0.00813 seconds
Time Before: 0.03420 seconds
Time After: 0.03460 seconds
Time Before: 0.03716 seconds
Time After: 0.03838 seconds
Time Before: 0.03323 seconds
Time After: 0.03857 seconds
Time Taken: 0.00534 seconds
Time Before: 0.06665 seconds
Time After: 0.06681 seconds
Time Before: 0.43049 seconds
Time After: 0.43180 seconds
Time Taken: 0.00132 seconds
Time Before: 0.44146 seconds
Time After: 0.44163 seconds
Time Before: 0.44456 seconds
Time After: 0.44654 seconds
Time Taken: 0.00198 seconds
UPDATE session SET lastactivity = 1780612207, location = '/forums/private.php?do=newpm&explain=1&u=119556', badlocation = 1 WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.46391 seconds
Time After: 0.46424 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
