Time Before: 0.00341 seconds
Time After: 0.00493 seconds
Time Taken: 0.00152 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.00500 seconds
Time After: 0.00565 seconds
Time Taken: 0.00065 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.00591 seconds
Time After: 0.00606 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.00673 seconds
Time After: 0.00977 seconds
Time Taken: 0.00304 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.00611 seconds
Time After: 0.01314 seconds
Time Taken: 0.00704 seconds
Memory Before: 560.883 KB
Memory After: 1,641.883 KB
Memory Used: 1,081.000 KB
Time Before: 0.01558 seconds
Time After: 0.01595 seconds
Memory Before: 2,136.727 KB
Memory After: 2,137.344 KB
Time Before: 0.01834 seconds
Time After: 0.01968 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,148.789 KB
Memory After: 2,148.648 KB
Time Before: 0.01500 seconds
Time After: 0.01987 seconds
Time Taken: 0.00488 seconds
Memory Before: 2,128.906 KB
Memory After: 2,261.672 KB
Time Before: 0.02840 seconds
Time After: 0.02856 seconds
Memory Before: 2,815.242 KB
Memory After: 2,815.758 KB
Time Before: 0.03331 seconds
Time After: 0.03459 seconds
Memory Before: 2,903.539 KB
Memory After: 2,904.133 KB
End call of global.php: 0.036265134811401
Time Before: 0.03827 seconds
Time After: 0.03843 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.04056 seconds
Time After: 0.04235 seconds
Time Taken: 0.00179 seconds
Memory Before: 3,821.875 KB
Memory After: 3,823.563 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=119557'
Time Before: 0.05946 seconds
Time After: 0.05973 seconds
Memory Before: 4,295.492 KB
Memory After: 4,295.734 KB
Page generated in 0.058576107025146 seconds with 9 queries, spending 0.0091977119445801 doing MySQL queries and 0.049378395080566 doing PHP things.
