Time Before: 0.00233 seconds
Time After: 0.00323 seconds
Time Taken: 0.00090 seconds
Time Before: 0.00332 seconds
Time After: 0.00388 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00417 seconds
Time After: 0.00437 seconds
Time Before: 0.00511 seconds
Time After: 0.00783 seconds
Time Taken: 0.00272 seconds
Time Before: 0.00444 seconds
Time After: 0.01132 seconds
Time Taken: 0.00688 seconds
Time Before: 0.01343 seconds
Time After: 0.01386 seconds
Time Before: 0.01680 seconds
Time After: 0.01808 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01279 seconds
Time After: 0.01825 seconds
Time Taken: 0.00546 seconds
Memory After: 2,261.703 KB
Time Before: 0.02501 seconds
Time After: 0.02514 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02736 seconds
Time After: 0.02865 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.030424833297729
Time Before: 0.03200 seconds
Time After: 0.03213 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03419 seconds
Time After: 0.03566 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=119613', badlocation = 1
Time Before: 0.04823 seconds
Time After: 0.04848 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.047302961349487 seconds with 9 queries, spending 0.0084631443023682 doing MySQL queries and 0.038839817047119 doing PHP things.
