Time Before: 0.01267 seconds
Time After: 0.02015 seconds
Time Taken: 0.00747 seconds
Time Before: 0.02025 seconds
Time After: 0.02080 seconds
Time Taken: 0.00054 seconds
Time Before: 0.02114 seconds
Time After: 0.02130 seconds
Time Before: 0.02207 seconds
Time After: 0.02433 seconds
Time Taken: 0.00226 seconds
Time Before: 0.02136 seconds
Time After: 0.02844 seconds
Time Taken: 0.00708 seconds
Time Before: 0.03520 seconds
Time After: 0.03565 seconds
Time Before: 0.03820 seconds
Time After: 0.03950 seconds
Time Taken: 0.00131 seconds
Time Before: 0.03454 seconds
Time After: 0.03973 seconds
Time Taken: 0.00519 seconds
Time Before: 0.05478 seconds
Time After: 0.05491 seconds
Time Before: 0.06835 seconds
Time After: 0.06966 seconds
End call of global.php: 0.071593046188354
Time Before: 0.07884 seconds
Time After: 0.07899 seconds
Time Before: 0.08127 seconds
Time After: 0.08274 seconds
SET lastactivity = 1785366913, location = '/forums/private.php?do=newpm&explain=1&u=119639', badlocation = 1
Time Before: 0.09973 seconds
Time After: 0.10004 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.098659992218018 seconds with 9 queries, spending 0.0080831050872803 doing MySQL queries and 0.090576887130737 doing PHP things.
