Time Before: 0.00182 seconds
Time After: 0.00232 seconds
Time Before: 0.00240 seconds
Time After: 0.00274 seconds
Time Before: 0.00347 seconds
Time After: 0.00362 seconds
Time Before: 0.00448 seconds
Time After: 0.00748 seconds
Time Taken: 0.00299 seconds
Time Before: 0.00370 seconds
Time After: 0.01148 seconds
Time Taken: 0.00778 seconds
Time Before: 0.01415 seconds
Time After: 0.01456 seconds
Time Before: 0.01769 seconds
Time After: 0.01890 seconds
Time Before: 0.01355 seconds
Time After: 0.01915 seconds
Time Taken: 0.00560 seconds
Time Before: 0.02650 seconds
Time After: 0.02670 seconds
Time Before: 0.02873 seconds
Time After: 0.02994 seconds
Time Before: 0.03313 seconds
Time After: 0.03327 seconds
Time Before: 0.03557 seconds
Time After: 0.03706 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=119708' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05035 seconds
Time After: 0.05065 seconds
